Question about Z-400 fan
Old Feb 23, 2004 | 07:35 PM
WhiteZRacer's Avatar
Default Question about Z-400 fan
My friend has a z-400 and when we drag race in the field his fan turns on about 10 times to mine turning on about 1 time.I just wanted to know why it is doing this.
White Z-400
W/B Full Exhaust
Powerfilter
Suzuki Shock Covers
ITP Baja Wheels
Old Feb 23, 2004 | 10:37 PM
z400fmf's Avatar
i may be wrong but i think it turns on when it reaches a certain temperature... maybe he revs it up a little more
Old Feb 24, 2004 | 10:54 AM
dumboldfart's Avatar
My brother and I were wondering the same thing about his Z, the fan hardly ever ran. I think it just runs efficiently.
Old Feb 24, 2004 | 03:40 PM
Corpsie's Avatar
Part has to do with the heat transfer to your coolant from the engine and heat transfer from the coolant to the outside air (via the radiator)
Heat Transfer to the coolant is due to combustion temperatures and transfer time. The transfer will be higher if you're
1. Running with higher load (aka more throttle opening)
2. Running at a lower RPM (gives more time to transfer the heat)
3. Have a higher % of water in your coolant mixture
4. Running normally or lean (running rich will actually cool down your combustion temperatures)
For the heat transfer from the radiator to the air, it will be higher (aka less fan time)
1. Running at higher vehicle speeds (more air through radiator)
2. Radiator is clean (more air through radiator)
Old Feb 24, 2004 | 04:37 PM
eiger2's Avatar
Make sure your radiator is clear. Little mud can cause big problem.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
