napa hose rejet?????????
Old Feb 25, 2004 | 06:24 PM
moosin's Avatar
Default napa hose rejet?????????
i was thinking of doing the napa hose mod on my 650 but just wondering if i had to adjust or change any jetting dont want to do either. (past jettingproblems) and agin what is the napa part#. thanx for any help.
Old Feb 25, 2004 | 06:34 PM
nyroc's Avatar
It is 7335. You probably won't need to rejet.
Old Feb 25, 2004 | 07:08 PM
trailride's Avatar
I didnt have to rejet, but any more air coming in and anymore exhaust going out i would.
Old Feb 26, 2004 | 01:13 AM
Hollywood917's Avatar
I didnt have to rejet mine but always play it safe and read your plugs (before and after) each mod.I just got my dynojet kit and gona begin my tweeking in the next few days.
Old Feb 26, 2004 | 09:26 AM
Guz's Avatar
Guz
Would adding a snorkle (DG or Napa) help a p700 that is running lean? A couple of times my p700 backfired through the carbs. It happened on my property and there wasn't a change in elevation. It always seems to happened in colder weather. I thought I read that backfire through the carbs- running lean / backfire through exhaust -running rich. Do I need to rejet or add more air, neither...? When this happened it also sounded weird. For example, when I had it in neutral it would idle and then rev like I gave it gas and then idle. Even if I turned the idling up it did it at a faster pace. Any suggestions or mods the fix. I also thought P650/700 had tendency to run lean. I should check my plugs.
Old Feb 26, 2004 | 01:54 PM
markdf's Avatar
Guz,
If the bike is changing idle speed significantly without you touching the throttle, I'd say the float needs adjusted.
Re: your question about more air, I'd say no. That probably would only worsen the problem. If it backfires as you let off the throttle, it's probably a lean condition. Another cause of backfiring that people don't think of is a leaky exhaust.
Hope this helps.
Mark
Sassinm1
Sep 30, 2015 04:23 AM
panicmanic
Sep 28, 2015 12:59 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
bigred20653
Sep 19, 2015 02:11 PM
