400 exers please help
Old Jul 8, 2000 | 10:42 AM
redridaz513's Avatar
my 2000 exer came from dealership with to much oil my dad said not to worry,6hrs later i went to change my oil and broke a bolt off in on the oil filter cover,i took it back to dealer ]ship ,they then put to much oil in it again,arent you sopose to warm the engine first to get a correct reading??? please help thanks
Old Jul 8, 2000 | 11:04 AM
Motorhead's Avatar
The engine takes 2 quarts of oil when you do an oil change, no more, no less. To check the oil properly, according to the service manual, park it on level ground, let it idle for 5 minutes to warm up, then shut it off, and a minute or two later check the oil by unscrewing the dipstick, wipe it off, then re-insert the dipstick WITHOUT screwing it in, pull it back out, and it should read in the cross-hatched area. If it's too full, you run the risk of blowing out a seal somewhere. If it's not full enough, you know what that can do.
Old Jul 8, 2000 | 04:45 PM
trx430ex's Avatar
ouch! Put some high temp grease on those threads too.
Oh, And be very carefull not to put the oil filter in backwards.
Old Jul 8, 2000 | 06:12 PM
400exalltheway's Avatar
it doesn't take 2 quarts. maybe around 1 3/4 when warmed up and ran
Old Jul 8, 2000 | 07:44 PM
THEXOTIC1's Avatar
On a new bike or a fresh rebuild the manuals say to add more oil . Check your manual for the correct oil measurement.
Old Jul 8, 2000 | 08:21 PM
Motorhead's Avatar
According to the service manual page 3-1:
Engine Oil Capacity: After draining/filter change: 1.95 US qt. (after disassembly: 2.3 qt)
Old Jul 9, 2000 | 11:43 PM
azrob's Avatar
1.95 quarts is what my 400EX took on its first oil change. I did just what the service manual stated.
Blaster2fast
Nov 18, 2002 10:45 PM
DSAPP
Mar 12, 2001 11:52 AM
exer
Feb 22, 2001 06:09 PM
redridaz513
Aug 7, 2000 08:05 PM
