First valve adjustment????
Old Feb 26, 2004 | 08:44 PM
ROCKAFELLA's Avatar
Default First valve adjustment????
I just bought an 04 rancher 350 es and I noticed that the first valve adjustment is after only 15 hours. I have never had an atv, but I know with street bikes, the valve adjustments are after several thousand miles. What do you guys think and do many people follow the manual to a T? So when did you guys have your done? Thanks for the help
Old Feb 26, 2004 | 09:03 PM
ponyboy's Avatar
Hello, Yes it is important to do I did mine after 5 tanks
Old Feb 26, 2004 | 10:10 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Yup, and don't wait that long to change the oil and filter too.
Old Feb 26, 2004 | 10:17 PM
Specta's Avatar
I follow the manual pretty close. So far I am convinced my ATV's will run forever too.
If I do a little too much maintenance a little too often, then all I am out is a little time and money. What I do have is two ATV's that are dependable and run excellent.
Old Feb 26, 2004 | 11:51 PM
Rancherat400's Avatar
I do not do my own maintenance, because I am not mechanically inclined. I will tell you that after the dealership adjusting the valves changing oil and adjusting all the things I thought needed adjusting, the bike ran like a raped ape.
The front brakes were fine, but the rear brakes were really poor. They adjusted them, now they are great. Front end needed alignment, I had them set the idle, what ever else they did.
If you are mech, go for it, but I would make sure I had the valves checked when Honda suggests to do it.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
