can't get the little red light to go off!
Old Feb 27, 2004 | 08:43 PM
BajaBomb's Avatar
Default can't get the little red light to go off!
i have done a oil change recently.i've ridden it twice scince then with no problems.now i get on it and it lights up real dim.it's still bright when you turn the key on but once it's cranked it gets dim.anybody else had this problems or any ideas??
Old Feb 27, 2004 | 08:55 PM
400CatDriver's Avatar
Did you bleed the air out of the system? Did you wash it lately with a pressure washer? That will mess up the oil sensor sometimes. My DS lost one of the check valves and had to be opened up and fixed.
Old Feb 27, 2004 | 09:10 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Dont run it until you check the oil res filter, its the oil line on the bottom of oil res... Pull out the filter and make sure it is not clogged up... Do this just to save yourself ALOT of $$. Mine went dim and what not, But it was tooo late for me, needed new bottom end after a few runs .
Old Feb 27, 2004 | 11:26 PM
TheOz's Avatar
I had this exact same problem, the light dimming to about half the full brighness after the machine was started. I took it to the dealer to have it fixed "twice I'll add". They said it was a sender switch. I haven't rode much because of winter so we'll see what's up in the spring. Although my warranty is now up.
Old Feb 28, 2004 | 07:58 PM
anth's Avatar
WHEN you TURN the key before you START IT shod the red light be on?
Old Feb 28, 2004 | 09:16 PM
Yes, because you don't have any oil pressure.
Old Feb 28, 2004 | 10:34 PM
AdamsBadDS650's Avatar
Mine sensor went out once, too. Whats funny is the dealer charges a sh!tload to replace them, or you can go buy one at autozone for around $4. Maybe someone on here knows, but I think one for some chevy model works. Anyone know what I'm talking about?
Old Mar 14, 2004 | 08:26 PM
BajaBomb's Avatar
problem solved...it ened up being the oil pressure sensor. the fan sensor went out at the same time! must have had some kind of little power surge or something. ( or maybe got them too wet at the car wash!)
Old Mar 14, 2004 | 09:02 PM
TheOz's Avatar
How did you figure the fan sensor went out too?
Old Mar 14, 2004 | 10:36 PM
BajaBomb's Avatar
well my fan just wouldn't come on. so a way to test it is to take a fuse and connect both of the wires coming out of the sensor and turn your key on. if the fan comes on the sensor is your problem.
