Dalton clutch cover-V
Old Feb 29, 2004 | 04:36 AM
Pistonman's Avatar
Default Dalton clutch cover-V
I just now ordered the EPI pink spring, I'll start there. Wondered if Dalton cover is worth it, will it work well with pink spring? or does it work better with Dalton blue...or pink with a couple shims..Have K&N, waiting for Muzzy and jet kit....Maybe pink is all I need? For sand & woods rec riding.
Old Feb 29, 2004 | 09:29 AM
Quadfather's Avatar
From what I've read in the past few weeks, the pink spring will work well with the stock exhaust. Once you add an aftermarket exhaust, and a higher flowing air filter, the pink will not add that much performance. The Dalton Pro kit (blue spring with weights) seems to be the trick. The blue spring and pink spring are pretty close in shiftout, so maybe adding the weights with the pink would work.
The people that are using the Dalton cover seem to like it. It makes the bike rev out faster.
Old Feb 29, 2004 | 01:00 PM
VNASTY's Avatar
Need stronger spring like a HPD Plain with the weights,I have had all 3 springs and like the HPD the best.It pulls better from bottom to top.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
