How Often Should I Change Hub Oil... 03 Sp 400...
Old Feb 29, 2004 | 06:39 PM
sethaloo's Avatar
Default How Often Should I Change Hub Oil... 03 Sp 400...
How often.. should i Change the Hub oil on My 03 Sportsman 400..... How Do i? What Should i Use?
Old Feb 29, 2004 | 06:44 PM
Bradracer18's Avatar
I think you just remove the tire, and then take the cover off. I'm not sure, but your owners manual should tell you how to. I would just use the recommended Polaris hub oil at you dealership.
Old Feb 29, 2004 | 08:51 PM
highwayman's Avatar
If you have external hubs like I do on my 335SP I change them 5 or 6 times a year it is very simple just take wheel off each side, remove set screw and drain fluid, fill at 12 o'clock and then drain at 4 o'clock replace set screw and you are away. I use a synthentic ATF for hub fluid which is cheap so I do it more than recomended. If you notice a lot of wheel drag you should change the fluid.
Old Feb 29, 2004 | 09:02 PM
ftwflh's Avatar
Check it every couple rides . Change it once a year and use polaris awd fluid.
Old Feb 29, 2004 | 09:27 PM
predatordude's Avatar
I believe polaris recommends checking it every 25 hrs. / 250 miles, and to change it annually. Definitley use Polaris Hub Fluid! Using different oils can cause unwanted hub engagement.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
