Jet-Hot question
Old Mar 1, 2004 | 11:10 AM
Pistonman's Avatar
Default Jet-Hot question
Jet-Hot coated pipes radiate 50% less heat( which can increase HP through higher exhaust gas velocity) but where does all the heat go? Out the pipe? I have heard it will Increase engine internal temp as well. Does anyone know how much?
Old Mar 1, 2004 | 12:46 PM
Doctorturbo's Avatar
GOT BOOST!
Yep, it goes out the pipe. My local coating man has several different coatings for different applications. There are coatings that trap heat, coatings that radiate heat, coatings that just look good and protect from rust ect.............. and on and on and on................
If you have a nice open pipe it should not increase the temp. If you don't, it will depend on how much back pressure you have.
Oe more thing. The coatings that some people use are thick. If you get the inside of the pipe done you should go up one pipe size to compensate for the lost space.
Old Mar 1, 2004 | 12:51 PM
TechTip101's Avatar
I have mine Ceramachromed. I believe this is the same thing. I noticed I do not get hot spots on the pipe and it does seem a little bit zippier.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
