Clamp on K&N and wheelie bar for predator????
I have 2 ??? ..... I put a clamp on k&N filter on my predator becuase i had to rip my airbox out for the pipes and it is running bad.... It boggs out whenever i go to stab it like its getting to much air... Does anyone know if this could be the problem or if it is something else,, i am also running a 170 main... Also i was doing some wheelies yesterday and the grab bar hit in the back and bent right away... The end caps on my pipes also bent and are shot now.. does anyone know if there is a bar out for the pred that is straight and long that will go past the pipes and not bend when i hit the ground???? thanks for the help
ok thanks, do you usually have to change the pilot jet also
stock jettin is 150 main and a 45 pilot... when adding a clamp on and my pipe i am at 172.5 and a 50 pilot and it is a tad lean up top... gonna try a 175 or 177.5 this weekend
