What is the stock 300EX gearing?
20" Holeshot tires are roughly about the same size as 22" Otusu(stock) tires. The only difference is that the Holeshots are not as rounded as the stockers.
13/38 - 2.92 final drive ratio
13/39 - 3.00 final drive ratio
Top end will not change enough too notice.
If you install 18" tires, or 22" tires. Then you will notice a change in top end.
Changing 3 teeth in the rear sprocket is equal to changing 1 tooth on the front sprocket.
Chris 00' TC Racing 300EX
