Scrambler Clutch assembly Question
Old Mar 4, 2004 | 12:17 AM
SCA's Avatar
SCA
Default Scrambler Clutch assembly Question
Hi all,
As you may remember I has some problems with my 99 500 Scrambler clutch. After alot of good advise I decided it was better to find a different one. I found one on EBAY (a new take-off from a dealer) and it arrived today.
I knew that it didn't have a spring or weights which is good as I had a clutch kit on my original one. I installed the weights without a problem, and was going to install the spring when I noticed that the spider was loose. No big deal I thought as I have the tools to put it together.
I went to my factory manual to check the torque specs and to double check what I did so far was correct. I read in the manual that when a clutch is disassembled, you need to keep the X's aligned to maintain the balance. I noticed that the X on the spider and the X on the clutch cage itself were not lined up. The X on the spider and the clutch top cover were lined up.
Before I torque the spider down, should I line up the X's on all 3 parts?
thanks
Steve
Old Mar 4, 2004 | 12:19 AM
fishslab's Avatar
I'm gonna go with a yes on this one.
Old Mar 4, 2004 | 01:22 PM
quadracer18's Avatar
Ya,,,I would,,,I have a 2000 500 scrammy and it notes in my manual to MAKE SURE IT IS LINED UP. they bolded that in my book so it should be important.
Cole Hadden
Jun 15, 2025 09:05 AM
ghost civic
Jan 15, 2020 07:43 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 13, 2015 05:11 PM
200es
Jul 10, 2015 09:09 AM
