V-700 YOSHI DUALS,DG SNORKEL,DYNOJET, SO NOW DO I NEED TO ADD THE DIAL-A-JET SYSTEM
Old Mar 4, 2004 | 12:26 AM
CRASHDOG's Avatar
Default V-700 YOSHI DUALS,DG SNORKEL,DYNOJET, SO NOW DO I NEED TO ADD THE DIAL-A-JET SYSTEM
OK I HAVE NOW GOT THE NEW DG SNORKEL AND I HAVE TO INSTALL IT, I HAVE ALREADY GOT THE YOSHI EXHAUST ON WITH A K&N FILTER AND I INSTALLED THE DYNOJET KIT AND IT WORKS FINE FOR NOW, I WAS WONDERING IF I PUT THE NEW DG SNORKEL ON IF I WOULD BE BEST ADDING THE DIAL-A-JET SYSTEM ON BEFORE REJETTING, I AM HOPEING IT WILL BE A LITTLE LEAN WITH THE NEW SNORKEL INSTALLED AND THE DIAL-A-JET WOULD BE JUST WHAT I WOULD NEED, IT DOES GOOD ON STARTING AND LOW END SO I SHOULDNT HAVE TO WORRY ABOUT THE NEEDELS OR THE SCREW ADJUSTMENTS I HJOPE.
ANY INPUT OR SUGESTIONS ARE WELCOME.
THANKS ALOT IN ADVANCE.
CRASHDOG, SEEYALATERBYE
Old Mar 4, 2004 | 02:30 AM
Pistonman's Avatar
Check out " Dynojet jet size " thread. I'm working on this , will post any findings.
Old Mar 4, 2004 | 07:54 AM
HappaRap's Avatar
Lazy Boy Rider!
What range of DB level are thos Yoshi's putting out, I assume they are duals.
Old Mar 4, 2004 | 10:25 PM
CRASHDOG's Avatar
hey rap,
i honestly dont know, but compared to other bikes i ride with i seem to be alot quiter,
my pipes make a deep sweet sound (like raw horse power) not to loud though.
and yes they are duals
Old Mar 4, 2004 | 10:51 PM
Mister's Avatar
I have the Yoshi duals(TRS tri-oval) and installed the TEC quiet kit to keep the noise down. Without the inserts they are very loud. With the medium insert in it brings the decibal level down to about 96 still too loud for my taste. I have the smallest insert in and it is barely louder than stock with a real nice tone. You will have to re-jet depending on which TEC insert you will use(even though Yosimura says you don't have to). The Look, fit and finish of the Yoshi duals are excellent. I still messing around with the jetting but definitely noticed a power increase, even more so with quiet kit....Oh F.Y.I... you have to buy 2 TEC kits to go with the dual system.....
speedbuff
13
Nov 11, 2020 10:16 AM
Customer Service #1
May 15, 2020 08:46 AM
Oct 10, 2015 10:20 AM
Sep 30, 2015 01:37 AM
