p700 frame welding???
Old Mar 4, 2004 | 10:06 AM
mammy's Avatar
Default p700 frame welding???
is there any places on the p700 frame that should be welded or gusseted for racing or jumping. i was looking at the strut towers and
thinking maybe i should start there. any suggestions?
Old Mar 4, 2004 | 10:16 AM
Prairiewrench's Avatar
The upper strut mounts are the only thing that needs to be done! I have done a few of them. My email is is below in my profile, email me your number and I will call you and tell you how I do it and I believe I have some pics somewhere also.
Old Mar 4, 2004 | 10:40 AM
newbeatle's Avatar
I also had to gusset ( regusset better ) the rear rack supports, & replaced the cast aluminum rack supports ( which also support the rear fenders )... however this was a result of too much jumping, with stuff on the rear rack... ( I only noted this, if you intend to do informal jumping, with stuff on the rear rack... also forum members have reported breaking these cast aluminum supports easily, by bumping trees... mine are stainless, but could have been made out of heavier gauge aluminum if you wanted ) if you remove the rear rack, the stock supports would work fine for just the fenders...
IMO, most of the problems with the front srtut towers results from bottoming out the front suspension, with the front rack removed ( the front rack, helps support the shock towers... I have a heavey gauge aluminum strut support that goes between the towers... adding aftermarket springs like the Elka system reduces bottoming out, & greatly reduces the stress on the towers...
PRAIRIEWRENCH won't steer you wrong on supporting the shock towers...
Old Mar 4, 2004 | 11:54 PM
mammy's Avatar
hey prairiewrench, were did you get the tag setup and how do you like them. i'm looking at get a differant handlebar setup.
Old Mar 5, 2004 | 01:42 AM
LittleBoy's Avatar
Mike Penland sells the PBR adapter for Tag handlebar. Phone number 706-746-2812
Old Mar 5, 2004 | 04:51 PM
mammy's Avatar
does that come with the speedo adapter
Old Mar 5, 2004 | 07:03 PM
LittleBoy's Avatar
Yes, the speedo fits on the adapter, but the plastic handle cover doesn't
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
