02 sp700 help
Old Mar 4, 2004 | 06:34 PM
DrewNYsp700's Avatar
Default 02 sp700 help
I have a 2002 sp700, which has been a great machine for the past two years...For the first time I have actually overheated it pretty good. To the point it start to boil the anti-freeze. Fan didnt come on when the temp light was on, and speedometer pin was flashing. Got it home and let it cool. Used buddys service manual to troubleshoot, and I ended up jumpering the fan switch in radiator to make sure it wasnt the fan itself. Fan came on just fine. What should be my next step, should I replace the switch, or refill coolant and try again???
Old Mar 4, 2004 | 08:18 PM
markie's Avatar
Have you had the water pump problem on your 02 fixed yet buy the dealer.
Old Mar 4, 2004 | 08:31 PM
Polaridoo's Avatar
Should be the temp sensor on the radiator. If the fan spins when you give it 12 volts, then it probably is not getting the signal to turn on from the temp sensor. Run a test on it or just replace it.
Old Mar 4, 2004 | 10:23 PM
predatordude's Avatar
Also be sure your radiator is clean of mud and debris. Also be sure it's not losing any coolant or leaking, i'd check the color of the oil too, just to be sure the head gasket isn't leaking.
but it is probably the fan switch
Old Mar 6, 2004 | 02:08 AM
Thank you for all the comments everyone....I pulled the fan switch out of radiator only to discover that one out of the two wires was ripped right off. Just need to replace sensor now. Thanks again.
sprtsmnfan
Oct 7, 2002 08:51 PM
GE4x4
Feb 24, 2002 09:51 AM
GE4x4
Dec 2, 2001 05:16 AM
burnoffski
Dec 1, 2001 11:55 PM
ledebuhr1
Aug 29, 2001 10:10 PM
