how to change the belt
Old Mar 4, 2004 | 08:59 PM
HighOutput4x4's Avatar
Default how to change the belt
Got myself a new belt and need to put it on before the start of the weekend. Can anyone give me some easy instructions on how to do so on my new scram? Thanks again guys
Old Mar 4, 2004 | 09:05 PM
trailrider500's Avatar
This is very easy... Ok first remove the PVT cover i think its 9 3/8 bolts, the belt can just slip right off with out taking any clutch parts off.. Install the new belt take a look at the new belt and see if it has to rotate a certain way..
Old Mar 4, 2004 | 09:06 PM
Oh yeah, you may need to remove the rear mud flap to pull the cover off...
Old Mar 4, 2004 | 10:18 PM
predatordude's Avatar
Yep,
Remove the clutch cover on the right side. You may have to remove the footwell.
Pull the belt back over the driven clutch (rear), should slide right off.
Then pull off the drive clutch (front)
Install: Wrap belt around drive clutch (front) Be sure the belt is going same way as the one your removed by looking at the numbers on the belt.
When installing on the rear clutch, start by wrapping it around the top of the driven clutch (rear), while you're wrapping it around let the driven clutch rotate and the belt will wrap with the clutch and slide right on. 30 min. job at most
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
