Another number for the NAPA hose.
Old Mar 4, 2004 | 10:37 PM
EasterEgg's Avatar
Default Another number for the NAPA hose.
Thanks to Konanian for the heads up on which vehicle it fits because none of the Napa's around me had one. So I looked for another alternative or source and the hose is for 1987 Ford E250 van with a 6.9 litre desiel. Atleast this what I bought for $14 and it worked.
I tried the see what fits from the rack at the local Autozone with no luck, nothing large enough. The problem getting one to fit is the end that attaches to the airbox has to be larger than the most common hoses. The bend is not a perfect fit but it does work well enough after cutting to length and the opening is huge compared to the stock one.
Mine was an AC Delco part no. 22027M GM part no. 88907956
I'm sure most that wanted to do this mod have done it but you can never have too many options.
Old Mar 5, 2004 | 12:49 AM
newbeatle's Avatar
good work... there are alot of Canadians that will be happy to have that info... perhaps someone could post the other part numbers Gates, etc ???
Old Mar 5, 2004 | 12:13 PM
newbeatle's Avatar
KONA... this is very noteworthy info, I have saved those numbers, to help others, later, down the road... does anyone know if these work on the V Force as well, or if they are using a different part number ???
Old Mar 6, 2004 | 09:10 AM
piski's Avatar
Konanian,
I see you're using a product called Tow Kool ??? Is that available up here in Canada...if so from which supplier ? Did ya notice any improvements in temp ?
Jeff
ReconBayou
Oct 16, 2019 02:24 AM
Johnny Mac
Aug 15, 2019 03:13 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
