got spark got gas now what
Old Mar 7, 2004 | 02:14 PM
iwannabfast2's Avatar
Default got spark got gas now what
ok 95 scrammy got gas got fire wont start and ideas
Old Mar 7, 2004 | 02:48 PM
ScrambleMe's Avatar
Ok I've been following your story quietly. Sorry about your luck lately. They are good quads, they just need to be tuned right like anything else.
I'd say that if you have spark now, It could be a couple things, \
1. got spark but flywheel key is sheered so it fires at wrong time.. or,
2. had water in fuel tank, so that would explain popping and back fireing.. or,
3. all the tinkering with the carb and running great for a little bit meant you got it tuned a bit lean and started to melt you piston, and now you have low compression, so she just wont run now.
Remember when you break it down its only going to be 3 things,, spark, fuel, mechanical.
I'd start with a compression test. Very quick and easy test. Service limit in my Manual says 115psi. If you don't have a guage, then go get one. This wont be the only time you'll need one.
If thats fine then pull carb and check for water,, it will separate from the fuel, look in fuel bowl, then check for sheered pin. good luck.
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
you actually need fuel, air, spark and compression
do you have all of those?
Old Mar 7, 2004 | 04:10 PM
quadwrench's Avatar
Bing is right - you need air both ways - in and out. Two strokes have been known to plug up the exhaust system by oil rich mixes - doesn't happen very often, but does happen.
My first guess would be a compression problem - one quick test when you don't have a compression gage handy (as long as MAJOR problems haven't occured) is to pull the spark plug and pour a little motor oil in on the piston - this will "fill in the gaps" a little to boost compression and most times will allow it to crank
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
