Predator recall question
Old Mar 7, 2004 | 04:03 PM
mebcop's Avatar
Default Predator recall question
I have a 2004 predator and I'm seeing in the forums that they're going to be recalling them to fix the front brake hose problems. It is breaking where the single line that comes off of the hand brake splits into the two seperate lines going to each side of the front end. The problem on mine is that where the coupling goes into the T bracket it got bent or something and it was leaking, so I cut it off and put a compression fitting on it to hold me over until I bought a new brake line. Now they are going to recall it and mine is rigged up like that. Will they still cover that under warranty and just put a new brake line on it still? It's not gonna be any more work nor any more parts than normal, it's just that I've already kinda fixed it.
Old Mar 7, 2004 | 07:38 PM
predatordude's Avatar
It shouldn't matter, if it's a defect Polaris will fix it, it's kind of a safety issue, even if you have fixed it already. Just call your dealer and once they get the parts in they should be able to fix it under warranty.
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
