pred jetting....
Old Mar 8, 2004 | 08:42 AM
Hozed's Avatar
Default pred jetting....
i put my clamp on last fall... went to a 172.5 MJ and a 50 PJ... that was all i changed....
went to put my box back on because of mud water and i heard of the lost performance... put everything back the way it was before my clamp on... and at half throttle and above it cuts and pops like a MFer.... what could have happened...
Old Mar 8, 2004 | 04:03 PM
Hozed's Avatar
any1?
Old Mar 8, 2004 | 05:32 PM
fidge1's Avatar
You need to move your clip on the needle back to the 2nd notch, run a 45 pilot, and 150 main and it will run fine,, Make sure all the snorkal lines and air box is sealed properley. My pred is running mint with a clamp on and a 45 pj, 175 main, and needle on the 5th clip... def increased some hp,, but will have more when i get my original motor in it... Make sure all that is correct and then try it, there is no way that it can run shi**y,
Old Mar 8, 2004 | 07:02 PM
Hozed's Avatar
i never moved the needle... i ran a 162.5 with my pipe and k&n... before.... why cant i now... i dont get it.
i shouldnt have to go back to stock with my pipe and k&n
Hankey Pankey
26
Oct 18, 2020 03:50 PM
BYC
Sep 25, 2015 02:10 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
95wolv
Jul 1, 2015 10:02 AM
