V Force Fan Removal?
Ok my fan is fried... and I need to replace it (can not complaint bike has over 6000 miles on it and to date I have not had many problems). I can see the three bolts holding it in… is there and easy way to remove it or... do I have to remove the front plastic and radiator?
Thanks
RJ
Thanks
RJ
You can take one of the front shocks off to get the fan out.Take the bolts out,unplug the wires,and the vent up by the steering mount.That is the quickest way.Check your temp sensor on the radiator,I had a bad wire on mine.That made the fan not cycle on and off like it should.[img]i/expressions/face-icon-small-happy.gif[/img]
VNASTY,
Thanks... I will get to that later today. I’m pretty sure it’s the fan, because it’s making a grinding nose with a lot of resistance when I try and turn the blades.
P.S. That LED "TRX450R Tail Light" sounds sweet... good idea.
RJ
RJ
