lights
Old Mar 8, 2004 | 11:11 PM
Trailblazinrider's Avatar
Default lights
Today, i found a pair of 55watt off road lights. Will they work on my tb without doing or changing the electrical system?
Old Mar 8, 2004 | 11:14 PM
mudmaster250's Avatar
Default lights
one will work for sure but two may be pushing the limit. if u havnt bought them yet then i would suggest a set of moose lights or warn lights. they both have two lights and are both very bright. they come with wireing and mounting brackets and switches and anything else u need. they are a nice set up. scott
Old Mar 8, 2004 | 11:27 PM
Default lights
sweet! No, i havent bought them yet, and i wont now. Can someone give me a link to a site where i could check them out/ buy them? Thanks much for the help!!!
Old Mar 8, 2004 | 11:28 PM
Default lights
www.denniskirk.com they carry both. its your choice as to which are best becuase they are both great but the moose lights are 35 $ and the warns are 55$. scott
Old Mar 8, 2004 | 11:54 PM
Default lights
Ok, they look like nice lights. Do you (mudmaster250) have them on yours. (because it says that you have moose lights) If so, how do u like them compared to the stocker? Thanks again!
Old Mar 9, 2004 | 12:07 AM
Default lights
the difference with the lighting is literally night and day. they are great lights and they are waterproof too. i love them, before my grandma wouldnt let me ride at night much cuz i could never see stuff and when i got the lights she saw how bright they were and the first night i had them i went riding till 8:30. and she is overprotective. so that should tell u something, they shine about a half mile at least. they are super easy to wire up with the right tools. any more questions just ask. scott
Old Mar 9, 2004 | 12:11 AM
BT250racer's Avatar
Default lights
it should be fine to use to 55 watts lights i used 3 differnet pair on mine at 55 watts each and it didnt hurt a thing just hooked them to the wires for the orgianal light
Old Mar 9, 2004 | 12:28 AM
TreeDoc's Avatar
Default lights
I have 2 55w Halogens on my Sportsman and when I wired them the first time, I connected them to the Hi Beam circuit. I had a problem with excessive draw at times and they would cause the circuit breaker to trip which would kill the entire electrical system. I ended up wiring directly to the battery and putting a waterproof toggle switch on the headlight pod. The Sportsman only put out 240w from the stator, I'm not sure about a TB. Check your manual and that should give you an idea on capacity of your system.
Old Mar 9, 2004 | 12:59 AM
Default lights
i still say one of the kits would be less hassle.
Old Mar 9, 2004 | 08:20 AM
bisho12's Avatar
Default lights
Mudmaster,
Do you run the stock light and the moose lights at the same time? I have a 99 sport 400 and would like to put additional lights on it. Will it be able to handle it? Should i run 2 55w lights and not the stock one at all? What is your or everyone elses opinion? Thanks for the replys.
