Pro Design Kill Switch
Old Mar 9, 2004 | 02:18 AM
Pistonman's Avatar
Default Pro Design Kill Switch
Was looking for place to hook up, says for batt. equipped quad hook to pulse trigger wire on stator. Wonder if I could hook in line with vehicle down sensor to shut fuel pump along with ignition ? Or is that something that should be removed? Where do you hook the P.D. kill switch ?
Old Mar 9, 2004 | 02:34 AM
Pistonman's Avatar
I'll leave this posted in case anyone else was wondering... do advanced search of Pro Design-- good link there to explain hookup.
Old Mar 9, 2004 | 09:08 AM
MentalState's Avatar
all you should have to do is look for the grey wire in the keyed harness..Ground one side of your kill then hook the other to the grey wire.
Wham! your done.......
Old Mar 9, 2004 | 09:11 AM
Mark82ndABN's Avatar
This is the link I used to help install mine......pretty good instructions with several step-by-step photos: http://aerolite103.com/VForce2004/V-Force%202004.htm
Old Mar 9, 2004 | 12:04 PM
MikeyBoyesq's Avatar
Mentalstate is correct. I hooked mine up by connecting 1 wire to the gray wire coming out of the ignition key switch and connected the other wire to ground (I used a screw that bolts down the thermostat to the frame). Its easy to do, but I found it takes a little time b/c I had to remove the front fenders to get to everything.
Good luck and happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 9, 2004 | 05:50 PM
only thing I removed was black cover on front of atv...took 10 mins to hook up...
fordfaithful21
Dec 7, 2015 05:52 PM
nick c
Sep 13, 2015 10:08 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
toonces
Sep 5, 2015 01:14 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
