new belt ??
Old Mar 9, 2004 | 09:14 PM
Powerstrokinsportsman's Avatar
Default new belt ??
I just put a new belt on my 400 scrambler and it won't shift right... Just wants to wind out, let off a bit and give it gas again and it shifts. Seems like the more I ride it , the better its getting... does a new belt sometimes take a break in period?
Old Mar 9, 2004 | 11:53 PM
fishslab's Avatar
Default new belt ??
They do require some break in. I know all the quads I have put new belts on also wanted to creep a bit. Took a good hard ride or two and they were great. I was also using after market belts.
Old Mar 10, 2004 | 12:01 AM
BigBadScrambler's Avatar
Default new belt ??
You are actually suppose to scrubb a new belt in soapy water. They have a residue on them from the factory. They also do need to be broken in like Fishslab said
Old Mar 10, 2004 | 12:02 AM
JEFF10049's Avatar
Default new belt ??
Like fishslab said it can take a ride or two but if it takes more than that I would think you have some other probs. A good inspection of the primary clutch may be in order check the sheevs for a wear groove this can cause the prob. your haveing.
Jeff
Old Mar 10, 2004 | 12:05 AM
JEFF10049's Avatar
Default new belt ??
Good info on cleaning the new belt Bigbad that gets forgot alot thanks.
Jeff
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
