clutch cover torq. spec?
Old Mar 10, 2004 | 07:09 AM
busmechanic's Avatar
Default clutch cover torq. spec?
I have looked through the shop manual. can not find a spec on the clutch side cover bolts. the closest one I could find is the starter bolts that go into the cover. they are 10nm. same size bolt. so I geuss that will work. anybody know the spec?also the pressure plate spec would be nice to.
http://faq.f650.com/FAQs/F650_Torque_Table.htm
never mind. just found it.
Old Mar 10, 2004 | 11:20 AM
SANDMAN430's Avatar
89 inch pounds don't grap the big torque wrench for this one.
Old Mar 10, 2004 | 06:05 PM
R00ST's Avatar
just curious...do you need to tighten the bolts that hold the clutch springs down to a certain torque spec? or do they just tighten all the way?
Old Mar 10, 2004 | 10:19 PM
Eaglecollector's Avatar
They are the same...89 inch pounds
Old Mar 10, 2004 | 10:54 PM
done. test run this sat. winchester bay. the one thing I thought was unusual was the fact that there was a driven plate in the bottom of the basket. I would think that a drive plate with clutch material against the back of the basket would be better than metal to metal. or does it turn with the basket all the time?
SANDMAN430's Avatar
seems most of the small bolts are 89 inch pounds
Old Mar 10, 2004 | 10:59 PM
I used the 10nm instead of the inch pounds. due to the fact that my 3/8 torq wrench has only ft. lbs. and nm. I need to get a 1/4 drive torq wrench. as sandman says everything seems to be 89 inch lbs on the engine.
Njrider1230
Jul 29, 2023 05:16 AM
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
rawbdiggity
34
Sep 2, 2015 02:16 AM
ghost civic
Jul 15, 2015 10:48 PM
