skidoo snowmobile engine with a scramy trany?
Old Mar 12, 2004 | 11:06 AM
badazz400's Avatar
Default skidoo snowmobile engine with a scramy trany?
one of my buddies is trying to put a skidoo snowmobile engine on a 400 scramy frame. the problem is he needs a transmission. will a transmission from a 400 scramy/sport work on the skidoo engine?
all replies greatly appreciated
thanks
ross
[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 12, 2004 | 11:19 AM
CED's Avatar
CED
I just installed a rotax 700 into a sport frame ,the problem you run into is the clearance for the carbs.So i did away with the tranny and did a jackshaft instead,which gives you more clearance.Send me your e-mail and i will send you some pic's monday.
Old Mar 12, 2004 | 11:39 AM
Polarisboy2's Avatar
The tranny should not be a problem if you can get the clutches aligned but the problem will lie in the space needed for the carbs like CED said. Jay
Old Mar 12, 2004 | 12:07 PM
BuddyP's Avatar
By putting in the Ski Doo engine (I assume your going to use the TRA ski doo primary clutch) I don't think you can get a strong enough converter (secondary clutch) spring to keep it from overpowering the clutch and sucking in the belt. You may need to look into modifying the secondary setup to a Ski Doo snowmobile secondary clutch also. Then you can just put in stock clutching for that motor when it was in a sled and be close on your setup.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
