400ex keeps blowing the fuse
Old Mar 14, 2004 | 08:12 PM
ballbag's Avatar
Default 400ex keeps blowing the fuse
hey all my new problem is on my 400ex every time i try to go from high beam to low beam i blow my fuse i took the switch apart and cleaned the three contacts inside with a piece of sandpaper , traced the wires to the head light and found a hack job connection on all three wires repaired that , looked for any other defects and found none so now im lost any suggestions will be greatly appreciated
Old Mar 14, 2004 | 10:18 PM
ktk's Avatar
ktk
I know you don't want to hear this but there's still a bad spot somewhere and it's grounding out. Are you able to trace each wire individually or are they in a "loom"? Is there a place in the wiring that has been mashed or kinked or something like that. That could allow a break in the insulation and the high beam wire is grounding out on another wire or on some metal. Hope you find it quick. Sometimes these electrical gremlins can be a bear.
Old Mar 14, 2004 | 10:30 PM
ballbag's Avatar
i traced them 2 the headlights and then from there the brown one takes off to the taillight i did not chase it but will give it a shot thanks for the help
Old Mar 14, 2004 | 10:40 PM
ktk's Avatar
ktk
You could have a break inside the "loom" with two wires grounding out. I hate electrical problems. Dad has a couple old grain trucks that are truly a joy to work with regarding lights. Nothing can make you pull your hair out more than trying to find a bad connection/ground/etc somewhere.
Old Mar 21, 2004 | 11:19 PM
Quadkrazy400ex's Avatar
I have a 2003 400ex and soon after having it I had the same problem, mine was still under warranty so i took it in and was told that it had to do with the light wires grounding, trace the wires like ktk said and you will probably find the problem.
Old Mar 22, 2004 | 11:38 AM
hutchies's Avatar
I also had the same problem one night when i was out night riding with a group of friends. Really sucked we had to push start it all night. Took it back to dealer and they told me the same ole thing.
Lucas Bohanan
Sep 29, 2015 01:16 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
