Belt Deflection Switch Removal?
Old Mar 15, 2004 | 12:18 AM
wildwill's Avatar
Default Belt Deflection Switch Removal?
I really don't need that box on top of my cover so I would like to remove it and make a polished aluminum cover. The machine will not run onless the wires are connected though. I think the new CDI will cut that switch out anyway, if I remember correctly. Can I just pull the EBC fuse in the holder?
Old Mar 15, 2004 | 12:46 AM
Prairiewrench's Avatar
You can cut the two wires above the connection and solder them together. Everything will work fine then! I have a plastic welder and when I remover the switch I just took some black plastic and filled in the holes.
Old Mar 15, 2004 | 09:18 AM
newbeatle's Avatar
Yep... I removed mine ( as per PRAIRIEWRENCHE's suggestion ), but I don't have a plastic welder... I drilled out the poprivets that hold it, & riveted a thin piece of aluminum duct, on the inside, cut to fit the square, then used black silicone on the outside, to smooth over the top of the aluminum... you can't even tell it was ever there... at least when it's muddy anyways...LOL...
I'm thinking anout doing the same thing with the KBEC...
Old Mar 15, 2004 | 09:59 AM
If you are removing both the belt switch and the brake, just buy a V Force cover and put it on there. I have one for mine,,, now if I just had my 4 wheeler! LOL!!! Oh well,, Mickey has it looking VERY GOOD!!!
Old Mar 15, 2004 | 02:17 PM
wildwill's Avatar
Thanks Guys! I will do that.
user493
Aug 13, 2015 12:54 PM
jayking232003
Jul 23, 2015 05:48 PM
trouttracker
Jul 20, 2015 11:54 AM
Desimation2k8
Jul 17, 2015 12:37 AM
cornermike
Jul 8, 2015 11:44 PM
