Mods for the 500 scrambler 2004
Old Mar 16, 2004 | 02:06 AM
MrZeeedler's Avatar
Default Mods for the 500 scrambler 2004
I need to know all the mods i can do for my scrambler before may. I already have K&N, and ceramic coated pipe i need a deal on a muffler though anything i can run with db rating besides wb. I am going to pismo in may and i wanna spank some quads, i want to run nitrous but im getting a predator soon so i dont want to install on this. Please help me out. do u think i should do the airbox mod for sand? Gimme all you hp help so i can get a little more then 19hp to the rear wheel.
thanks,
kevin
Old Mar 16, 2004 | 07:43 AM
ftwflh's Avatar
Clutch kit and a roller action secondary.This will make a huge differance.
Old Mar 16, 2004 | 11:47 AM
quadracer18's Avatar
ya I would defenetly say a clutch kit also..that would be your best bet...and did you say you needed an exhaust idea other than white bros??? I didn't really understand what you were saying but if thats the case...probably the best setup for a scrammy would be hpd exhaust with an agressive clutch kit...as for the air box..I think you should be fine..but if you do change to a better airbox you'll get better airflow..but I don't know since you'll be in sand...for the nitrous..ya save it for the pred...One thing I think would greatly improve the scrammy is the weight..to heavy..but it will cost ya some money to lighten it up good...get a good wheel and tire set..will save you on weight and better performance.
Old Mar 16, 2004 | 06:09 PM
BigBadScrambler's Avatar
The HPD air box mods adds about 2hp (their claim) and really improves the throttle response. A clutch kit and TEAM clutch like the other mentioned would help also.
Old Mar 16, 2004 | 09:53 PM
4464's Avatar
I went with HPD's airbox mod but ended up dropping the main jet to a 165 because the plug was sooted up pretty good and the exhaust had soot also, so far the 165 jet is working good. I just wish someone would try the predator carb on srammy!
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
