Race Fuel Leaded or Unleaded???
Old Mar 16, 2004 | 04:31 AM
Sandaholic's Avatar
Default Race Fuel Leaded or Unleaded???
Before I do any engine work I have to make sure I can find a good source for racing fuel. One local shop wanted $12 a gallon for VP110!
I would like to go to a 14:1 (stock bore or 105.5), what is the lowest octane level I can run?
I noticed that different companies quote octane levels using different methods, R+M/2, MON, and RON. Ex. VP110 MON: 107, RON 113, R+M/2 = 110. I believe the method at the pump is R+M/2. So when I read claims that you need a minimum of 100 octane are there referring to R+M/2 method? Can someone set me straight on this.
Besides octane ratting, there is the choice of leaded or unleaded. Pros and Cons?
Last question, anyone know anything about F&L Racing Fuels?
Old Mar 17, 2004 | 02:50 AM
Sandaholic's Avatar
From what I have read the 14:1 is designed to run on 110 and I assume the are referring to 110 using the R+M/2 method.
Leaded or unleaded?
Someone has to have an opinion
Old Mar 17, 2004 | 03:45 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
I go by motor octane #
VP makes leaded fuels designed for 4-stroke, It burns better and runs cooler IMO.For 14:1 compression try c-14, If you are drag raceing it may be a bit more safe to run 114 for high reving passes. You can get away with a good brand fuel that is a true110 octane though.
STLyamwar
Jul 25, 2020 04:44 AM
WesTech
11
Aug 11, 2015 07:55 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Robinhood
Jul 13, 2015 09:13 PM
Unzzy66
Jul 11, 2015 10:01 PM
