Valve Adjustment....need info advice
Old Mar 16, 2004 | 03:06 PM
Entomber's Avatar
Default Valve Adjustment....need info advice
I got my shims in yesterday. I slapped it in but one of the exhaust valves is still out of spec. One I can stick the feeler gauge .007 maxium on one, but ther other I can clear .010. Do they both have to match up (same gap thickness). I want them to clear between .006 or .008 but my question is do BOTH have to have the same exact tolerance? I know this may sound like a dumb question it just I want to be absolutely certain this time and make sure my DS is in tip top tuned shape. Thanks to anyone who responds in advance. I
Old Mar 16, 2004 | 03:43 PM
ScoobyDFW's Avatar
I'd leave the cold clearance 0.007" alone and increase the other shim by 0.05mm, to put it at 0.008" cold clearacne. The cold clearances don't have to match, but 0.010" is a little big.
Or you can try heat cycling the motor once and re-check the cold clearance - if it is 0.009" afterwards you might leave it as is and re-check after full breakin.
By the way, over the years more than once, I've calculated what shims I needed and then when installed, I was still off by 0.05mm or 0.1mm. In the future, you'd save yourself time and frustration by picking up a couple different sizes close to what you think you need.
Old Mar 16, 2004 | 04:22 PM
Entomber's Avatar
Yeah I should of ordered the set. I ordered a few bigger in hopes it is what I need. I asked the guy to ship it next day. Let's see when it arrives. I'm actually glad I'm learning how to adjust the vavles. It seems pretty simple and straightforward. Once I break it in and get it going I will check it again.
slowgsxr97
Mar 18, 2022 03:40 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
