Stock head pipe vs aftermarket
Old Mar 16, 2004 | 07:58 PM
warrior68man's Avatar
Default Stock head pipe vs aftermarket
Exactly what is different about aftermarket head pipes then stock head pipes? They may not look the same, but I just don't see how it will improve performance at all.....especially if they say you should should buy a full system if you plan on doing major engine work later. I just don't understand the difference.....they seem exactly the same.
Later
-justin
Old Mar 16, 2004 | 08:02 PM
2003warrior's Avatar
The warrior stock pipe is a very good pipe. There is no need to buy a full system unless you want it for the looks.
Old Mar 16, 2004 | 08:05 PM
Really...hmm....Maybe I will take mine off some day, sand her down, and give her like 20 coats of 1500 Eninge paint, bake it on, then maybe it will look good....[img]i/expressions/face-icon-small-smile.gif[/img]
But, also on other quads, I just can't see the difference.
Old Mar 16, 2004 | 08:51 PM
turtleboy660's Avatar
For instance ... On raptors the head pipe diameter is somtimes bigger some aftermarket headpipes are the same diameter. Also were the two pipes merge together is usually a different length than stock
Reactant
Jul 27, 2015 07:45 PM
95wolv
Jul 21, 2015 12:25 PM
cSchwartz
Jul 12, 2015 07:42 PM
1966F100
Jul 12, 2015 03:08 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
