FRONT DIFF. OIL LEVEL QUESTION ?
Old Mar 17, 2004 | 07:32 AM
Never2High's Avatar
Default FRONT DIFF. OIL LEVEL QUESTION ?
WHEN REFILLING DO I BRING OIL LEVEL TO BOTTOM OF FILL HOLE ?
Old Mar 17, 2004 | 07:43 AM
piski's Avatar
yupper......good idea to check it after ya ride a little though..just incase
Old Mar 17, 2004 | 07:46 AM
hitman1970's Avatar
The oil level should come to the bottom thread of the filler opening.
Old May 16, 2004 | 01:59 AM
hardwood700's Avatar
Tried to put 0.45 qts in front diff. and it only took about 1/4 of that. whats going on? i drained about 1/2 a qt. out of it.
Old May 16, 2004 | 09:18 PM
92LT's Avatar
It takes a while for the level to drop after filling. For some reason the level drops slowly, so it can take a while to fill. Take your time and make sure it is completely full.
Old May 16, 2004 | 10:09 PM
589650's Avatar
I found when I did mine last that if you work the diff lock lever while filling the diff, the oil is able to go in faster. Helps to have an assistant. Hope this helps.
Old May 16, 2004 | 10:39 PM
Thanks alot guys. I thought I was going to havet to lay it on it's side. LOL
I'll try it tomarrow.
Thanks again.
JackTheKing
Jul 14, 2015 09:09 PM
200es
Jul 10, 2015 09:09 AM
jettman
Jul 6, 2015 12:16 PM
yambam13
Jul 4, 2015 01:49 PM
Mphillips
Jul 2, 2015 07:20 PM
