Another front hub question
Old Mar 17, 2004 | 08:14 AM
Bytor's Avatar
Default Another front hib question
I just replaced the inner seal of the front hub on my '04 SP400 (early model with the two front hubs). Now I notice a small leak around the drain/fill plug. I have it tightened down good. Can I use teflon tape on the threads of the plug or should I get a new one? Just hope the cast hub threads aren't trashed.
Thanks.
Old Mar 17, 2004 | 09:41 AM
Bradracer18's Avatar
Default Another front hub question
I suppose you could use teflon tape, but it is usually used on plastic fittings. worth a try i guess
Old Mar 17, 2004 | 10:54 AM
nez02's Avatar
Yea i would deffinatly try a little bit of the tape. Just make sure you dont use to much that way the access doesnt get inside your hub. Im sure it wouldn't be to good to have a huge chunk of tape floating around in your hub.
Keith
Old Mar 17, 2004 | 11:05 AM
RAJ's Avatar
RAJ
The tape should be fine...Just make sure you put the right oil in the hubs....Don't do what I did...I put 90 weight in them, and they would lock in on thier own. I went to polaris and bought the oil to put in the hubs. And also don't fill it up all the way. I think you need 4 oz. in each hub.
Old Mar 17, 2004 | 11:09 AM
nez02's Avatar
I was told to fill them even with the drain hole when it is a 3 o'clock. You should just want a little pour out. Hope this helped
Keith
Old Mar 17, 2004 | 11:22 AM
Bytor's Avatar
Thanks, I'll give the tape a try. As far as the oil, I am using the Polaris OEM. Polaris says that each hub holds 4 oz, and to fill them at the 4 or 8 o'clock position, letting the excess drip out. After I did this for both front hubs, I still have about 1-2 ounces left in the 8oz container. So either I didn't fill enough or they really only hold 3-3.5 oz each.
Old Mar 17, 2004 | 11:47 AM
Polaridoo's Avatar
After I fill up the hub, I will drive around for a few mintues and that seems to get the fluid well dispersed. Then I come back and recheck. Also, I had to use one or two layers of tape on the threads to make it stay perfectly dry.
Old Mar 17, 2004 | 12:03 PM
RAJ's Avatar
RAJ
I also had some left over, when I check them again they was full. I should have check on here before I did mine. I guess thats why I can tell people what not to do... Huh. Well good luck.
Old Mar 26, 2004 | 09:52 AM
camoman's Avatar
I just found out that my seals are leaking as well (03 SP500) . Are the seals hard to change? Any tips or tricks to doing it?
Old Mar 26, 2004 | 08:42 PM
Bytor's Avatar
I've gotta be honest. I had never done the replacement before and I could NOT get the rear seal out. Heated it up and pried and pried. I tried for at least an hour and got fed up. Took it to a car mechanic and it took him literally 30 seconds to get the seal out. He put the hub in a vice and just easily tapped the seal out from behind with a screwdriver. Boy did I feel stupid. He then cleaned everything up and put the new seal in. The best part? He didn't even charge me. Guess he felt sorry for me.
