problem starting lakota
Old Mar 18, 2004 | 09:28 PM
mdyjeepgrl's Avatar
Default problem starting lakota
Alright, today I figured I'd start up the lakota, considering that the last time I rode her was maybe a month ago. I charged the battery because when I first tried pushing the start button, the battery was dead.
So after charging it, she started up for a minute and stopped. Thinking it must be cold I kept trying and now she won't start at all. Believe me, it's not about the patience, becuse I have been out there for a while.
And another thing, I see that small specs of gas are coming out of the supertapp exhaust. Am I running too rich? What should I do?
Thanks for the help[img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 18, 2004 | 09:52 PM
50021's Avatar
its flooded, take out the spark plug and continue to charge the battery, start her up again and be easy on the choke, (with the spark plug out, the gas will evaporate and when all the gas is gone put the plug back in)
start it with the plug( wow that sounds like something an idiot would say)
let me know how it works out for you
Old Mar 18, 2004 | 10:34 PM
moochie's Avatar
jeepgrl....i had the same thing with my kota. Clean plug and let it sit overnight and next morning it will fire right up. What main jet do you run? Also what position is your mix screw? Thanks Chris
Old Mar 19, 2004 | 02:18 AM
mdyjeepgrl's Avatar
I think I'm running a 135. And as far as the mix screw, I'm not sure. I think it's two and a half turns from being completely screwed on tight (if that even makes any sense). What do you think, is the jet about right?
Old Mar 19, 2004 | 04:01 PM
moochie's Avatar
I'm at a 140 main with 3 turns out. It seems to run pretty good.
Old Mar 19, 2004 | 07:56 PM
sugarhead's Avatar
id take the plug out,spin starter w out plug to blow flooded engine out,take air filter out helps too.Put new plug in recharge battery or since the cold is bad on batteries a new 1 might be in store.if the jetting worked for u last year dont touch a damn thing.
Old Mar 19, 2004 | 08:52 PM
BigChris's Avatar
Hey,
Make sure the plug is good too...that was my problem for not starting!
Old Mar 19, 2004 | 09:03 PM
1WheelMoses's Avatar
It almost sounds to me like you might have a stuck float.If you can get to the side of the float bowl just give it a lite tap with something hard.This is quite common on motorcyles if they sit for longer periods
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
