Raptor Head bolts
Old Mar 19, 2004 | 01:37 AM
LOWBOWTIE's Avatar
Default Raptor Head bolts
Has anyone ever replaced them just for safty sake? Or has anyone came up with stronger ones ( I wish ARP would help us out).
Old Mar 19, 2004 | 01:39 AM
RaptorOwner's Avatar
When I had my 690 done I believe they put stronger ones and retapped the threads but I dont know for sure. I just take my stuff to the shop and they do it. I wish I could do it myself and save TIME and money.....[img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 19, 2004 | 01:41 AM
LOWBOWTIE's Avatar
RaptorOwner, I sometimes wish I had the $ to take it somewhere! But I know I wouldn't be happy.
Old Mar 19, 2004 | 02:18 AM
Outlawlawndragster's Avatar
In a perfect world they should be replaced every time . When you pull a bolt to toque it stretches the threads some what they will eventually loose there draw or "elastic state " and stretch out or go " Plastic " on you .
I believe the YFZ head bolt are ( toque to yield ) and they definitly should only be used once .
One other thing id you are reusing nuts flip them over sounds crazy but the threads will flex back the other direction
Old Mar 19, 2004 | 02:41 AM
LOWBOWTIE's Avatar
Thanks Outlaw, That's kinda what I thought I just wanted to know if I was dreaming or that I actually heard that somewhere.
Old Mar 19, 2004 | 02:57 AM
sparkskiller's Avatar
well the head bolts dont stretch that much its the threads in the aluminum that are pulling out over time. the holes are only good for 3- 4 torque sessions. then will require heli-coils. DO NOT run a tap into the threads to clean them up because it will take material away that is used to hold the bolts in. you must use a thread chaser.
Old Mar 19, 2004 | 03:00 AM
LOWBOWTIE's Avatar
Well that sound like something that would happen to me![img]i/expressions/face-icon-small-mad.gif[/img]
Old Mar 19, 2004 | 09:11 AM
Sparkskiller I disagree . All bolts stretch . When you torque a bolt you are stretching it and it is pulling back like a rubber band . If you over torque it loses it's elastic state and fails to pull and then it just keeps on stretching . Thats why torque values are so important . Also the cases (aluminum) are enginered with a certain amount of draw area to offset the bolts pull . I have had aluminum blocks that have had countless tear downs and reapps with NO failures .
Just always make sure the bolts or studs are lightly lubed You can still use locktite if nessacary but in small amounts .
Old Mar 19, 2004 | 10:51 AM
BigScary's Avatar
I'm running the stock bolts.......but they are heli coiled
Old Mar 19, 2004 | 11:44 AM
Ugintel's Avatar
I've had mine aprat 4-5 times, it still runs like a charm with a 660.......
