300EX MODS
Old Mar 20, 2004 | 12:01 AM
BRAD14's Avatar
Default 300EX MODS
i got a 98 300ex and this summer i was going to mod it out some more with motor work.i was going to add a sparks piston(.80),cam,rockers,and springs,new clutch and 400ex carb.how much might this run me and how big of a differenca will i notice my other mods are listed below also i was goint to put on some 22in super swampers.any help will be appreciated.oh and how much should it run me to get the cylender bored?
Old Mar 20, 2004 | 12:38 AM
BRAD14's Avatar
Default 300EX MODS
oh yeah,who make pistons for curtis sparks?
Old Mar 20, 2004 | 01:01 AM
manual's Avatar
Default 300EX MODS
If you want work done on your 300ex id suggest sending it into a place like powroll. Get a 352 kit, which comes with a high comp piston. Have them do headwork and a couple other things
Old Mar 20, 2004 | 08:37 AM
kingpin300ex's Avatar
Default 300EX MODS
Brad14,
When you changed out you front sprocket to a 14 did you have to take the case saver off. I have a 15 o nmine and i had to take my case saver off to fit it.
Old Mar 20, 2004 | 10:21 AM
BRAD14's Avatar
Default 300EX MODS
the case saver was already off when i bought it,and manual i dont make enough cash mowing yards to do something like that the mods i listed that i wanted is what i am prolly getting.
Old Mar 20, 2004 | 10:25 AM
SANDMAN430's Avatar
Default 300EX MODS
you could put a 250x cam in it there cheap and it helps.
Old Mar 20, 2004 | 11:27 AM
manual's Avatar
Default 300EX MODS
The mods you listed above will probally run you pretty high probally about to low 600's-low 700's. .80 you will need a new sleeve which runs $140 from every place ive seen. Than the boring should run around 60. 200 there. New cams run about 150-200, I wouldn't worry about rockers, springs run you about $130 which than again I wouldn't really worry about. New clutchs are about $60 from what ive seen, and a 400ex carb are probally about $75
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
