what weights should I use
Old Mar 20, 2004 | 08:56 AM
speedy63's Avatar
Default what weights should I use
I put a hotseat Green primary spring in my 04 Trailboss 330 and also the ITP mudlites,which are 24" instead of the 22" stock. I find that I need about 3 miles of straight road to hit top end now. I think that I should change the clutch weights to compensate for the stiffer spring and larger tires, but I'm not sure what size weights to get. The only other mods are the K&N and 130 jet. I have a ton of low end but hopefully can figure out how to get the top end right. Any input would be great. Thanks.
Old Mar 20, 2004 | 10:34 AM
Bradracer18's Avatar
My first instinct was to re-gear, but then you said that you have low end, so I'm at a loss, sorry can't help on this one.
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
