intake wont come off..... need suggstions
Old Mar 20, 2004 | 05:49 PM
R00ST's Avatar
Default intake wont come off..... need suggstions
Alright i was hoping to get my intake off to Mr.HP today, but upon trying to take it off (and i was warned about the tricky top screw)
i started to strip the top screw out....
i tried tapping it with a hammer but it wont budge even with that (i was using ball-end allen wrenches as well)
does anyone have any trick they would like to share as to how to get it off?
I was looking at it but dont know if i can get at it with needle nose vice-grips
any help is appreciated !
Old Mar 20, 2004 | 05:56 PM
PUSHINTHELIMIT's Avatar
Hammer and a chisle is how I got mine out. Pain in the a$$ and time consuming but it will break it loose.
Old Mar 20, 2004 | 06:00 PM
R00ST's Avatar
so you put the chisle up against the intake and just tried hitting it until the actual intake moved?
i was using a socket extension (only thing i had around me that would work decently) and a hammer with no luck....
Old Mar 20, 2004 | 06:06 PM
No, go from the side of the quad and try to rotate the bolt using the hammer and chisle.
Old Mar 20, 2004 | 06:18 PM
R00ST's Avatar
hmmm....
how do you get the chisle to break the bolt lose? (is it just by vibration?)
and how do u get the chisle in there?
Old Mar 20, 2004 | 06:23 PM
It's hard to explain but you just try to rotate the bolt by tapping on the side of the bolt with chisle and hammer. Keep in mind you're trying to rotate the bolt not break it off, lol. there's enough room to get a chisle in there as long as the seat is off.
Old Mar 20, 2004 | 06:26 PM
R00ST's Avatar
i think i see what your saying (just dosnt seem like it would make it come off)
maybe ill try using a flat blade screw driver... (dont know if i have a chisle)
Old Mar 20, 2004 | 06:58 PM
crashnburn's Avatar
When I took mine off I removed the bottom two bolts first and turned the intake. It loosened the bolt and gave me better access to the top bolt. I still had to use a ball end allen wrench.
Old Mar 20, 2004 | 09:19 PM
1BigDSRider's Avatar
Have someone twist the intake counter clockwise while you try and turn the screw. It helps.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
