K&N filter for predator 90
Old Mar 21, 2004 | 01:24 AM
sidehill's Avatar
Default K&N filter for predator 90
have predator 90/04 thinking about installing a K&N filter, and was wanting to know If anyboby new the part no. of the filter that I might need. According to the K&N catalog they don't make one for the predator.
Old Mar 21, 2004 | 02:24 AM
spike99's Avatar
For K&N Filter that fits minis, surf - Press Here -
Note: The dealer names are at the bottom of the page.
Hope this helps...
Old Mar 21, 2004 | 11:25 AM
terd's Avatar
Would you happen to know the part # on that K&N filter?
Old Mar 21, 2004 | 12:33 PM
sidehill's Avatar
Thanks for the info.It really helded. I live in Canada and trying to get any info. here is diffuclt. Mini Quads performce parts are hard to find. Thanks again.
Old Mar 21, 2004 | 03:03 PM
spike99's Avatar
Here's a few cuts / pastes from another forum. Please verify before purchasing...
Note: Depending on location & other mods, jet 90, 120 & 13x seems to be the common jet sizes. It all depends on the altitude of the rider's location and other mods as well....
I have installed both of the versions of Hetrick pipes on my boys 03 Pred. The version in the picture can be installed without removing the battery. The rear mount that you drilled out to bolt through the frame pipe is the side it should be on. It is a tight fit, but does fit perfectly. Did you buy the upgrade kit or just the pipe? The kit should include a 90 jet that seems to run great out here. I'm glad your happy with the pipe Rich and Michele have helped me out immensely.
Big happenings tonight! I got the uni filter with the cover in the mail, got home from work with a fistful of spark plugs ready to work on jetting, slapped on the uni and new plug and yeeha! it took off like a rocket, I don't know why (bad plug?) but oh man! I ran it at half throttle for 2 minutes and checked the plug and it was a beutiful beer bottle brown, next I'll run it full throttle to check the main jet. I think Michelle sent me a 120 main (is that right?)
Get an outerwear for it, be it the red foam one, or the fabric one. It will get caked with sand, but that is what it is supposed to do. The better way to go in sand is the "K&N RU 0200 with an outerwear", but you will be just fine with the UNI, that is what I run, it just gets real dirty after a weekend of riding. I run a 110 in the 50, so not surpewised to see 120 in the 90.
Hope this helps...
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
