13/22, 14/26 same results or not.
Old Mar 21, 2004 | 10:53 PM
Voodoo52's Avatar
Default 13/22, 14/26 same results or not.
Ok I went up to a 13 T on the lt80 with the 22 rear. But I was thinking maybe going to 14/26. Would I get the same speeds and low end?
Also I've always heard 4T on the rear = 1T on the front. Is this right? How many teeth equals 1" on tire size?
And if you do go bigger on the front you can't pull the R's out of the motor as good. So if you go bigger in the rear does this really help?
Old Mar 23, 2004 | 05:27 PM
RoadDoc's Avatar
Voodoo I read an article in Dirt Wheels that said that 1 tooth differance on the front is equal to 6.6 teeth on the rear. We raced flat track before going to MX and the 6.6 to 1 ratio is very close. Some say that if you go to small on the front it will cause more resistance as the chain rolls around the smaller sprocket. Some say that a larger front sprocket has more rotational mass on the front and slows acceleration. I'm not sure how you would messure the resistance either way. It probably isn't noticable to the average machine. I always felt that a smaller sprocket on the front let the bike rev quicker but that is only my opinion and observation from my experience. Having an assortment of different size rear sprockets let you better dial in gearing on different tracks. I don't know the mathmatical formula but I hope this helps a little.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigred20653
Sep 19, 2015 02:11 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
