DAJ/Carb Problem Solved! Rejetted & Found a kink in vent hose
FYI: I finally resolved my DAJ/carb problems by rejetting the carbs last Saturday (dropped 2 sizes on the main jets) in an effort to get rid of the surging problem I was experiencing when going 30 mph or more. When I experienced this surging problem, I concluded my carbs were running too rich for the DAJs to work properly.
This morning, I finally got to do timed runs at 100' and 300' and top-speed runs and discovered that the surging problem was completely gone, however my quad ACCERERATED A LOT SLOWER and my top-speed was ONLY 56 MPH (it was 62 mph BEFORE I rejetted). The quad seemed very weak and would I could not pull wheelies easily like I did before rejetting. It also backfired more than usual when I let off after WOT. Otherwise, it ran pretty smooth...just slower than usual.
Turning on the choke to 3/4 open, it seemed to speed up the quad a little bit. So I initially thought it was now too lean with the smaller jets, but then I discovered that the gas tank vent lines were moved to the edge of the top of the gas tank (about 2 or 3 inches to the side) which probably restricted or kinked part of that hose. After I moved the vent hose back into the slotted space, my quad instantly ran better than ever! I retested it and it accelerates better than ever, it pops wheelies again very easily, has awesome throttle response and my top-speed is the fastest ever on flat ground (63 mph). I'm very happy that I rejetted and found the kinked vent hose...Problem Solved!
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Not sure where you got that...what I said was it ran better than ever after I moved the vent hose to its appropriate position. I was running way too lean with the kink in the hose.
Thats it--I have made the mental decision that I am going to rejet my 360 DOWN at least two sizes and prove to myself once and for all if the dial a jet really works!!!
toonces
Oct 16, 2019 12:11 PM
