ABOUT TO ORDER A SET OF WEB CAMS. HAVE A COUPLE OF QUESTIONS.
Old Mar 23, 2004 | 10:12 PM
saint650's Avatar
Default ABOUT TO ORDER A SET OF WEB CAMS. HAVE A COUPLE OF QUESTIONS.
I AM ABOUT TO ORDER A SET OF 109/110 CAMS. I WILL BE GETTING THE TI VALVE SPRINGS FROM ALBA. THEY SAY THEY A WEB CAMS VALVE SPRINGS SO THEY SHOULD BE FINE. MY FIRST QUESTION IS SHOULD MY SHIMS BE THE SAME WITH THE NEW CAMS AND SPRINGS AND WILL I HAVE TO REMEASURE AND ORDER NEW SHIMS? CAN I USE THE SAME SHIMS OR IS THERE DIFFERENT ONES FOR USE WITH THE WEBS? CAN I EXPECT TO REJET AFTER THE CAMS? THIRD I AM GOING TO ATTEMPT TO CHANGE THE SPRINGS WITHOUT PULLING THE HEAD. I AM GOING TO BLOW AIR INTO THE CYLINDER TO HOLD UP THE VALVES. ANY TIPS?
Old Mar 23, 2004 | 11:30 PM
Eaglecollector's Avatar
Yes it will require the same type of shims. Yes you will prolly have to change them. I would be very surprised if you got lucky enough to not have to. You might get lucky and jst have to swap them around. Prolly not though. Can't help ya with the springs. Maybe someone else can though.
Old Mar 24, 2004 | 12:11 AM
Domi's Avatar
pull the head off, its much easier to change the valve springs that way
Old Mar 24, 2004 | 12:30 AM
Sandaholic's Avatar
Saint650, if you have not already purchased the cams I would suggest you contact Mr. HP, I heard he as some nice cam setups.
Old Mar 24, 2004 | 05:16 AM
saint650's Avatar
i went to mr hp website and do not see anything on cams. dose he cary the same web and ron woods cams? all i want out of a set of cams is to be able to pull up to 8-9000 rpm where now it drops off a ittle over 6000
Old Mar 24, 2004 | 09:38 AM
UBETRUN's Avatar
Don't use air to hold the valves closed, use rope. Feed rope through the spark plug hole until you can't get any more in there and then rotate the crank until it won't budge. The rope will hold the valves against the seat so you can get the springs off. There is a tool for compressing the springs to remove the keepers, get it. If you try to "pry" the springs, you can easily slip and bend a valve stem. Nylon rope won't leave any fibers in your cylinder after you finish.
Old Mar 24, 2004 | 11:37 AM
222's Avatar
222
He carries Webcam grinds and his own grinds. They don't seem to be on the website.
222
Old Mar 25, 2004 | 03:30 AM
saint650's Avatar
with the 109/110 cams can i use the dual valve spring kit? how much farther up do these cams make power. i am looking for it to pull hard up to 8000 rpm
Old Mar 25, 2004 | 11:56 AM
222's Avatar
222
The 109/110 cams are good cams, giving good over rev and more top end power. But they were designed for a much lighter F650 bike - they give up some bottom end and mid range - something I feel the DS needs more of instead of less for most riders. I would recommend the atv designed Horsepower Research cams.
222
Old Mar 25, 2004 | 03:10 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
[img]i/expressions/face-icon-small-happy.gif[/img] Very pleased here.
2quiker
Mar 22, 2022 08:36 PM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
bvolks
Sep 13, 2015 12:57 PM
cornermike
Sep 10, 2015 08:30 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
