Weight Reduction
Old Mar 24, 2004 | 01:56 AM
Drunkfool's Avatar
Default Weight Reduction
i was wondering what some signifigant ways to reduce the weight of my '03 Baja? any knowledge would be appreciated
Old Mar 24, 2004 | 03:42 AM
SANDMAN430's Avatar
change the rear swingarm, and aftermarket pipe helps 04 head light helps sprockets, rims that should get yet you started.
Old Mar 24, 2004 | 05:18 AM
xray's Avatar
Try the Atkins diet.
Xray
Old Mar 24, 2004 | 08:19 AM
BajaIowa's Avatar
Titanium rear axle, '04 aluminum front a-arms
Justin
Old Mar 24, 2004 | 11:11 AM
SANDMAN430's Avatar
look at everything it takes a little here and there to add up.
Old Mar 24, 2004 | 12:39 PM
DSengineer's Avatar
Has been here a long time!
I would start by removing all of the Baja accessories (skids, bumper, aux lights, handguards, etc) These are easy to remove and put back on and wont cost you a dime.
Old Mar 24, 2004 | 06:39 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
Depends on the intended use of your ride.
I managed to reduce the over all weight of the wife`s bike by just over 80 lbs and I`m not done yet !
Old Mar 24, 2004 | 08:17 PM
Eaglecollector's Avatar
Originally posted by: Forcefed
Depends on yout intended use of your ride.
80lbs [img]i/expressions/face-icon-small-shocked.gif[/img] Dang ya got a list of what you did to drop 80
Old Mar 25, 2004 | 02:55 PM
Forcefed's Avatar
I updated "My page" it has some pics of the frame mods.
In addition to the frame (almost 15lbs)...
Solid suspension all the way around with alum struts....
Chromoly swingarm with Banshee carrier holding a JJ&A 40mm alum axle twisting alum hubs all the way across.....
Alum A-Arms....
520 chain & sprocket conversion....
.125 wheels
ALL non-essentials removed (bumper & tabs - grab bar - skidplate - airbox - FRT fenders - FRT brakes - and so on.....
Mr. HP lightweight components coming soon.....
This bike is application specific of course.
Fuse that type of weight loss with an insane 650 built by Horsepower Research and it should prove to be quite an enjoyable sensation when the clutch is dropped !
[img]i/expressions/face-icon-small-happy.gif[/img]
I`ll weigh it when its finished and report the final number for you.
Old Mar 25, 2004 | 05:00 PM
ScoobyDFW's Avatar
wow, a lot is taken off that frame!
