Wheel spacers for Lakota/Mojave
Old Mar 24, 2004 | 10:10 PM
BigChris's Avatar
Default Wheel spacers for Lakota/Mojave
Hey all
any body running wheel spacers for their kota or mo?
how they work?
do these ad extra wear and tear on the arms and axle?/shocks?
i think the kota would look sweet nice and wide...
any suggestions? thanks!
Old Mar 24, 2004 | 10:56 PM
iamnothing's Avatar
Actually, I'd like to know too! I bought a set of Dirt Devil's for our Lakota, and they rub the battery casing. I was thinking about wheel spacers, but I don't need to go 1-1/2 inches out. Anybody know of an easy 3/4 inch spacer or sinilar that doesn't need new studs?
Old Mar 24, 2004 | 11:24 PM
clover's Avatar
the wheel spacer are not good at all on a lakota,i put some on mine and it has terrible bump steer and if you plan on jumping your lakota the rear will break your axle.If you don't mind the bumpy ride and don't jump, get them it does handle better,but i wouldn't recommend them.
Old Mar 25, 2004 | 08:21 AM
BigChris's Avatar
Clover...
those really are some good points...
I just want her wide for looks and for steering...but what you say makes sense....i ride pretty aggressively and jump alot...so i guess i will not get them probably...
but i think im planning on getting some new tires....Im thinkin 20 inch in the back
anybody runnin 20 inchers?.....im curious to see how much acceleration i gain...and how much top speed i loose.. i have a 13 t sprocket..
oh also..would these 20inch tires make it easier to wheelie?
thanks~~!
Old Mar 30, 2004 | 10:43 PM
mgc420's Avatar
i am running rear 1 inch spacers on my 02 kota they solved my tire rubbing issue and i have had no problems.
Old Mar 30, 2004 | 11:42 PM
clover's Avatar
something you may want to look at maybe is some new aluminum wheels with wider offset.
Old Mar 31, 2004 | 12:04 PM
juniorsmojave's Avatar
i got twenties on the back of themojave and a13 tooth front sprocket, i think you will find you will gain a little acceleration but still have more top speed then stock.
Old Apr 1, 2004 | 08:01 AM
BigChris's Avatar
Good good thats what I was hoping for
thanks
Old Apr 1, 2004 | 08:55 PM
MojaveThunder's Avatar
hey juniorsmojave, how hard was it to put that 250r shock on it? How does it sound like with that E-Series on it? looks good. I have Razr 2's on my Mojave mounted on Douglas red label rims. I keep em' polished, matter of fact it's an 2002 and it looks like it just came off of the show room floor. I want to get a full system Big Gun exhaust with a race core, but the tires rub the exhaust, so I have to fit that first. Thanks
Old Apr 2, 2004 | 03:32 AM
mojave thunder, the 250r rear shock is pretty easy. the first thing is to look at yours and on the bottom of the stock shock mount there is welded on spacers on the inside of the mount. they have to come off. it is a tight area to work, but if you have a die grinder with a tapered bit you can do it. go slow and do a little at time until the bottom of the shock fits. the rest is bolt in, easy. the best part of the mod is you can send the shock in to be revalved and set up for your weight and riding. as far as the white bros. exhaust, i heard the supertrapp is better but louder, to be honest my mojave goes plenty good and i like not risking the noise level. i hope this helps.
