Plugging carb heater hose question on V-Force.
Old Mar 25, 2004 | 04:59 PM
Mark82ndABN's Avatar
Default Plugging carb heater hose question on V-Force.
Is there anything I should be aware of when plugging up the small hoses that carry coolant to the carbs. Down at the pump is a no-brainer but up at the carbs I'm not to sure on...... especially where the small hose leaves the carbs and goes back into the larger radiator hose return line just in front of the battery box is what I'm concerned about. What is the proper way to seal those off. Thanks!
Old Mar 25, 2004 | 05:36 PM
VNASTY's Avatar
I used a flanged bolt with rtv on it to plug the waterpump,make sure an cut the bolt the same length as the nipple that was in there.Cut a piece of hose about 3 inches to plug the carbs up,make a u bend with hose to each nipple.To plug up the head connection I left about 2 inches of hose and pluged it with 1/4" alum.plug with a hose clamp to keep it tight. Hope this helps!!!!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 25, 2004 | 05:57 PM
VNASTY, exactly what I was looking for......thanks!!!
Old Mar 25, 2004 | 07:51 PM
wildwill's Avatar
Mark,
I can show you when every we run in to each other?
Old Mar 25, 2004 | 09:50 PM
higgsV's Avatar
what do you gain by doing this?
Old Mar 25, 2004 | 10:18 PM
VNASTY's Avatar
The carbs run cooler in hotter weather.Cool air means more horsepower and one less hose to leak coolant.
Old Mar 27, 2004 | 07:43 PM
higgsV's Avatar
ah, thank you. i wonder how warm it has to be before you can do this? it's only about 45 degrees here today and that was pretty warm.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
green giant
Jul 13, 2017 12:07 PM
Ty Speece
Jul 2, 2015 04:59 PM
VRRRRT
Jun 27, 2015 09:38 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
