Mojave Low end power
Old Mar 25, 2004 | 07:53 PM
hondaguy1's Avatar
Default Mojave Low end power
What is the best and cheapest way to make a mojave have more low-end power. Mine doesnt have the greatest low-end power but is awsome on top end. I want more low end. THANX
Old Mar 25, 2004 | 09:04 PM
juniorsmojave's Avatar
with the 13 tooth sprocket i would get some 20 inch tires to gear it down a little, and a pipe, jet kit and filter. with the twenties and the 13 tooth sprocket you will still have more topend then stock but a good bottom end too.
Old Mar 25, 2004 | 09:54 PM
hondaguy1's Avatar
I have 20 inch tires i forgot to put them on my signiture
Old Mar 25, 2004 | 10:49 PM
mahnster's Avatar
Get a pipe filter and jet it, if still not satisfied drop a couple teeth on the rear sprocket.
Old Mar 25, 2004 | 11:24 PM
hondaguy1's Avatar
MAHNSTER: what do you think about the white brothers pipe, k & n filter and a jet kit. Should i be able to do wheelies easier. THANX
Old Mar 25, 2004 | 11:53 PM
mojaveaddict's Avatar
A pipe and jet kit will not help much on the low end but are worth it for the mid and top you pickup. Dropping teeth on the rear is the wrong way for bottom also, it will make it worse. If you want more bottom go back to the 12 tooth frt. You will have more bottom but will loose top speed. It will wheelie easier too.
Old Mar 26, 2004 | 01:11 AM
for more top end gear add a tooth to the front, drop teeth in the back, for more bottom end drop a tooth in the front add a tooth in the rear. no offense but if you are having problems with a wheelie change technique. i have a 13 tooth front sprocket and 20 inch tires in the back. i can get my front end up pretty easy, in first gear.
Old Mar 26, 2004 | 04:32 AM
rockrider's Avatar
The lack of low end response is due to the stock CV carb. I've been meaning to try a pumper carb off a 400EX as I understand that it is a bolt on and brings out the snap but I haven't done it. There was a thread about converting to it but I could not find it using the search.
Old Mar 27, 2004 | 04:12 PM
hondaguy1's Avatar
Actually, i am starting to look for a 300ex. I am thinking about selling my mojave.
Old Mar 29, 2004 | 10:25 AM
not a smart move
