Best way to "string-up" nerf bar nets?
Old Mar 25, 2004 | 08:20 PM
R00ST's Avatar
Default Best way to "string-up" nerf bar nets?
im going to be installing my pro pegs soon and want to go ahead and "string-up" the netting.
The TINY insructions my FAVORITE company included, were smaller than the size of a post-it note, and were not even legible at ALL!
does anyone have a close up pic of how it is to be done? i tried a few different ways, and what SEEMS should be right, is coming UP from the bottom, then going in the middle, then back down the bottom. the only problem i see with this, is it dosnt totally secure the net.... are they suppose to be tight enough in there that they dont slip out when u put pressure on them? (becausei can pretty easily just pull the netting right out)
Any pics or instructions would be a great help
Old Mar 25, 2004 | 08:34 PM
Fakeracing's Avatar
A screw driver (or butter knife), pair of needle nose pliers, 3-bandages and a nice quite place to relax when your all done[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 25, 2004 | 09:03 PM
snowbuster's Avatar
when your done, u see how well it works[img]i/expressions/face-icon-small-wink.gif[/img]lol
Old Mar 25, 2004 | 09:21 PM
R00ST's Avatar
lol, ok. Do you guys know how to install them though?
like which way do i route the strap through the slots
Old Mar 25, 2004 | 09:47 PM
satmike's Avatar
How many groves are there in each location,3 or 4? I just installed mine with 4 slots and you start at the top going in and out through the middle, back in going down, and the out the last slot. I had enough strapping left that I just tucked it in the side of the loop.
Old Mar 25, 2004 | 09:49 PM
R00ST's Avatar
it has 3 slots
Old Mar 25, 2004 | 09:54 PM
satmike's Avatar
Just cut a fourth slot! LOL. Are all the slots the same size?
Old Mar 25, 2004 | 10:09 PM
IndyPred's Avatar
For a 3 slot set-up you go down through the top slot and continue down through the bottom slot. Then you take the strap around the outside of the bottom slot and go through the middle slot. Once it is in the middle slot then you go back up the top slot so it is actually under the strap that you started in the first place. Hope this made sence cause I dont have a way to get you a picture.
Old Mar 25, 2004 | 10:11 PM
satmike's Avatar
Indypred good discription, I hope that works for Roost!
Old Mar 25, 2004 | 10:24 PM
lilnotts's Avatar
if u can wait til tomorrow nite i can get you a picture of mine, my quad is gone at the moment so i have to wait
