Toe In/ Toe Out?
Old Mar 27, 2004 | 10:25 PM
beetlegus's Avatar
Default Toe In/ Toe Out?
Be easy on me guys, I'm a little new at this. What is Toe In/Toe Out and where do you change it on the V Force?
Old Mar 28, 2004 | 01:03 AM
nyroc's Avatar
Toe in is when the front tires are not parallel. The front of the tires should be slightly closer together than the opposite (pigeon toed).
You adjust it by shortening or engthening the tie rods. The tricky part is getting the measurement right.
Most vehicles run 0 to 1/16" toe in. I set my 650 for 1/16" and it handles better at high speed. It came with 1/2" toe in and it stunk with bigger tires at high speeds.
