Dial-a- Jet on V Force
Old Mar 29, 2004 | 12:35 AM
Kawy's Avatar
Default Dial-a- Jet on V Force
How many of you are running the dial a jet? Are you guys happy with it, was it worth the $98 bucks, any noticeable improvements?
Old Mar 29, 2004 | 09:54 AM
MagnumMudMan's Avatar
Kawy
I am not running the dial a jet on a v force, but a 400ex. It does work and does give you an easy change to make small jetting adjustments. I often switch between a k&N and the stock filter depending on how dusty the conditions are. The dial a jet allows me to adjust the jetting for this. I got my ex out on Saturday and hadn't rode it since last October (I know, that's sorry). The last time that I rode it, I had the K&N in it. I put the stock filter in and rode it around and it was running rich (bogging, sputtering). I brought it in the garage, set the dial a jet back to the central position, and it ran great. So it does give you that quick fix option.
Is it worth the $98. Hard to say. If you are running the same set up consistently, just jet it and leave it. If you are running a variety of conditions and set ups, then it probably makes sense.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
