check belt light finally came on........
.......it didn't LOOK bad to me, a couple mm narrow compared to new one. i changed it anyway while i had it apart, now it hooks up better but it squeaks at idle. is this bad? also, i didn't see any black or gray wires to reset the light either. anybody help me out?
I don't know if it's the same for the V. On my P650 it's just above the clutch cover, tucked up behind the plastic ferring. You'll find 2 square connectons aprox 1/2 inch sq. each ; one black, one gray. With the key in OFF pos. Disconnect and swich them(black connected to grey , grey to black). Turn key ON for about
five seconds then back to Off . Connect them back to normal(blk on blk. grey on grey).
Belt light should be reset. Those connectors have 3 or 4 wires on each of them. You cant miss em.
______________________________
P650, 2003
Holeshot Module
Dalton Clutch Springs
ITP Cast Alum Rims
26in Bear Claws
Full Equiped
Kimpex Snow Trax (for deep snow)
P650, 2003
Holeshot Module
ITP Cast Alum Rims
26in Bear Claws
Full Equiped
My buddies V's belt light has come on. His dealer had no clue on how to reset it. Are these instructions good? Do they work on the V? He has tape over the light now. Probably did that with his fasten seat belt light in his truck too.LOL
Its easy. The connectors are under the seat on the V. Check out " ATV power.com". I think thats the site. Its 2 four pin connectors. One black one grey. Just switch them (black to grey and grey to black). Turn ignition on for a few seconds. Be sure to switch them back.
i'll have to look again, didn't see the connectors before. thank you.
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
